Ford fiesta engine replacement pls help me : (
Old Jan 12, 2012 | 07:34 PM
andy09's Avatar
andy09
Red face Ford fiesta engine replacement pls help me : (
Basically ill explain my situation and if anyone could help would be great and many thanks in advance,. Basically i have a mk6 2003 Fiesta finesse and trying to put a 2007 1.4 fiesta engine in it , apart from the obvious bit such as steering rack needs to be changed im almost there. I am debaiting thou what would i need to do with matching up clocks to ecu etc as the 2003 has standard clocks and the 2007 electronic. I dont want to have to change dash and loom etc if i can help it so does anyone know a way round this please or any advice.. i.e if i put engine in and keep clocks the same as original 1.3 and ecu original could i get it working or use 1.4 ecu and 1.3 clocks if someone looks into ecu and makes adjustments etc? PLEASE HELP! ANY ADVICE WOULD BE GREAT...
Old Jan 12, 2012 | 09:02 PM
andy09's Avatar
andy09
Also what thinking maybe use a 1.4 mk6 ecu and clock from a 03 rather that a 1.3 set to see if this works? hmmm curious now...
Old Jan 13, 2012 | 12:39 PM
KaTurbo's Avatar
KaTurbo
You've opened a can of worms here fella, shouldve done some research before you jumped in.
Old Jan 13, 2012 | 01:35 PM
oldford's Avatar
oldford
Sell the engine you have now and get a matching engine for your vehicle.
Old Jan 14, 2012 | 09:21 PM
Rsailor's Avatar
Rsailor
This is what I thought, you shouldn't try to mix mechanical and electrical components without
doing a little research.
Why do you want a newer 1,4 engine?
JoeyBoyden
Jan 4, 2024 02:36 PM
Botts
Aug 13, 2015 04:16 PM
Bosch
Aug 4, 2015 05:14 PM
