Fuel Computer
Old Apr 15, 2004 | 09:17 AM
Default Fuel Computer
I have a 1990 RS Turbo, it has a fuel computer, but it isn't connected, are they hard to connect? And is it possible, becuase im not sure if it came standard. Please help!!
Old Apr 15, 2004 | 12:14 PM
if u dont have the log book then its not your car yet!!
& i dont think its possible on red cars!!
Old Apr 16, 2004 | 07:22 AM
what ever
Old Apr 16, 2004 | 11:39 AM
stevedohc16v's Avatar
stevedohc16v
Theres a how to guide here
http://www.xrweb.co.uk/code/fuel.htm
Chances are someones just stuck the computer in the dash instead of the coin holder so none of the wiring etc willl be there (if it is the wiring multiplug will be there somewhere) the extra bits you need are the fuel flow sensor and the speed sensor, speed sensors ok as all MFI RST's/ XR3's/ Orion ghias with the computer and all post 90 EFI XR3/ Orion ghias are fitted with one, it goes on the top of your gearbox where the speedo cable goes in betwwen the speedo cable and gearbox, the fuel flow sensor is harder to get hold of as only the MFI cars with the computer fitted as an option have them ( EFI cars use an output from the ECU) the sensor fits on the side of the metering head.
The wiring to the fuel sender is already there under the back seat.
Even if you can't get hold of all the sensors you can wire the power supplies and fuel sender in and it will give you the miles remaining function (based on a default mpg of about 25mpg)
HTH
Steve
Old Apr 16, 2004 | 12:53 PM
Thanks, thats a great help!
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
