Escort van lights
Old Jan 9, 2012 | 04:54 PM
Fordmad!'s Avatar
Fordmad!
Default Escort van lights
Is there a relay for the drivers side headlight/back lights?
Baisically i had no main beam on the drivers headlight so i had a fiddle with it now ive lost all the lights on the drivers side.
Still have indicators, brake lights and flash but other lights won't work
I tested the voltage at the headlight plug and its not as much as the pass side so could it be the stalk? Even tho ive just put another one in.
Could the rears cause the fronts to go?
Checked the fuses and there okay
Old Jan 9, 2012 | 07:33 PM
Fordmad!'s Avatar
Fordmad!
Can anyone tell me whichg relays are for the lights?
Old Jan 9, 2012 | 07:37 PM
st220kyle's Avatar
st220kyle
if it was a faulty relay or stalk i would have thought there wouldnt be any voltage there at all
Old Jan 9, 2012 | 07:55 PM
Fordmad!'s Avatar
Fordmad!
I only get one reading on the drivers side so i guess this is for the flash/main beam as the lights still flash but don't get get anything else
Well the main plugs that goes into the headlights are different for some reason. One has 5 pins (drivers side) and one has 4 (pass side).
They havnt been changed so must be made like this for some reason.
I have changed the light but no luck.
I will try my other stalk and check rear earth aswell tomorrow. I have to check what im getting at the multi plug at the stalk to see if theres power getting to the stalk.
I suspect its a relay or the plug as they worked (apart from dipped) until i took the light out and had a look then i lost on the drivers side
Old Jan 10, 2012 | 08:18 AM
Fordmad!'s Avatar
Fordmad!
Theres power at the plug for the stalk.
Checked the rears they look okay cany see any problems there but theres no power at the plug apart from one which must be indicators/brake lights.
What else can i do?
Old Jan 10, 2012 | 11:33 AM
Fordmad!'s Avatar
Fordmad!
Does anyone no which relay controls the lights?
Old Jan 10, 2012 | 07:48 PM
st220kyle's Avatar
st220kyle
i dont know which relay it is, but when you switch the lights on and off you should hear the relay clicking in and out, what are you using to test the plug which goes into back of the headlight?
Old Jan 11, 2012 | 12:33 AM
bailey1981's Avatar
bailey1981
Sounds like a bad earth maybe
Find what the neg is on light multi plug & check continuity to body of van or neg on battery
Old Jan 11, 2012 | 07:21 AM
Fordmad!'s Avatar
Fordmad!
Right have got them working now but still don't have dip on the drivers side. Could it be a faulty plug?
Vincereese
Jun 1, 2023 09:14 AM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
