How to fit siemens injectors to a cossie rail?
I'm away to buy and fit a set of these (55's) to my standard 4x4 cossie fuel rail, I am advised these need no fitting kit, is this correct?
When buying the injectors do I need to purchase anything else or do these fit in and away I go??? Also what about the standard injector retainer clips?
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Siemens injectors are a direct replacement. They don't need a fitting kit, they still use the retaining clips as per the standard injectors.
My only advise would be to lubricate the O ring seals with something like Vaseline to ensure they do not get damaged.
Zoggon
10-08-2015 10:39 AM
