ST170 engine light/oil pressure problems
Old Jan 1, 2012 | 09:14 PM
jonbear's Avatar
jonbear
Default ST170 engine light/oil pressure problems
Hi
I'm new here and wondered if anyone could give me some advice.
I've had an ST170 54 plate 2 litre 48,000 miles which I've had for 2 months. The engine warning light came on unexpectedly on Friday and now stays on, and the oil pressure gauge goes immediately to the centre of the dial when the engine is turned on. When I drive at sped, the arm on the gauge heads up towards the top of the dial.
Does it seem like the oil isn't pumping around enough? If I change the filter, will this help?
The car seems to have been well maintained.
Thanks in advance.
Old Jan 1, 2012 | 09:48 PM
dug112y's Avatar
dug112y
passionford pro
engine management light or oil pressure light?
Old Jan 1, 2012 | 09:50 PM
jonbear's Avatar
jonbear
Engine management light
Old Jan 1, 2012 | 10:04 PM
dug112y's Avatar
dug112y
passionford pro
is the operation of the gauge different to what is was. It sounds ok as when the revs rise so does oil pressure. but it should drop slighty at idel when warmed up.
for management light you need to get fault code checked . sometimes the lambda sensor is to blame.
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
