Eprom key 101 encryption board, P8 ecu
Old Dec 29, 2011 | 11:04 PM
brunocon's Avatar
brunocon
Default Eprom key 101 encryption board, P8 ecu
A bit of a long shot this, but does anybody know where i can get a Key 101 encryption board that the eprom chip fit's into on a P8 ecu.
I have an escort cosworth with a P8 that has a collins powerchip, but in the days when tuners didnt want there chips copied mine has a Key 101 encryption board fitted that the chip plugs into so the car will run, but being heavy handed i have broke some pins on the encryption board. I have had some new pins fitted but now the car starts, runs for about a minute then stops and wont start again unless the board (not the ecu)is unplugged then plugged back in again, but then just does the same again. So i am pretty sure there is still a prblem with the encryption board.
Old Dec 30, 2011 | 03:28 PM
martysmartie's Avatar
martysmartie
Perhaps try contacting Collins?
Martin
Old Dec 30, 2011 | 07:45 PM
brunocon's Avatar
brunocon
Martin
Yep i am going to do that on Tuesday after the hols, i just thought someone might know of another avenue i can go down if Collins cant help.
Old Jan 1, 2012 | 08:08 AM
Stu @ M Developments's Avatar
PassionFords Creator
If they cant, we can fix it for you. Would cost about £40.
Old Jan 1, 2012 | 09:00 AM
brunocon's Avatar
brunocon
Thumbs up
Thanks Stu, i will try Collins on Tuesday if they can't help i will give you lads a bell.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
griffo69
Oct 4, 2015 11:58 AM
