Superchips
Old Feb 21, 2005 | 08:13 PM
cossy's Avatar
cossy
Default Superchips
The chip is "DARK.E2S SUPERCHIPS Tested AP Version 1.1" is it compatible with Escort 1.6 16v 1993? :blonde:
Old Feb 21, 2005 | 10:40 PM
Stu @ M Developments's Avatar
PassionFords Creator
Depends if you have the tag code "DARK" on your ecu
Old Feb 25, 2005 | 02:57 PM
cossy's Avatar
cossy
what`s the difference between the original ecu and the "dark" one?
Old Feb 25, 2005 | 07:23 PM
All the ecu's have what we call a "Tag Code" These are generally four characters long and spell a word.
Take a look at the sticker on the ecu access port and see what it says on there.
Old Mar 4, 2005 | 12:28 PM
cossy's Avatar
cossy
It says AGED now what?
Old Mar 4, 2005 | 01:07 PM
Its for an ECU with Tag Code AGED.
No use to you im afraid pal.
Old Mar 4, 2005 | 03:01 PM
cossy's Avatar
cossy
so what`s the difference? may I replace them?
Old Mar 4, 2005 | 04:53 PM
cossy's Avatar
cossy
It`s interesting that u have 5 different chips for 1.6 16v... so there is 5 ECU`s with different tag names... ?!?
Old Mar 4, 2005 | 05:02 PM
sailorbob's Avatar
sailorbob
Same basic engine but Ford alter things all the time and a tweak to the ecu is required each time. Ford will even change the ecu if they find a bug in their software. As an aside all new Fords have the same ecu and the software is all that changes, sometimes they update the software during a routine service if theres an update available.
Old Mar 4, 2005 | 05:32 PM
cossy's Avatar
cossy
is there a change in the kw/bhp?
...and what will happen if I put "dark" chipped ecu ?
Old Mar 4, 2005 | 05:44 PM
sailorbob's Avatar
sailorbob
The short answer is I've no idea, without knowing what changes Ford made it's anyones guess.
Maybe Superchips would be helpful if you asked them about the chips compatibilty.
Old Mar 4, 2005 | 05:46 PM
cossy's Avatar
cossy
I mean new ECU with the DARK tag name, and then to put the chip
Old Mar 4, 2005 | 06:13 PM
sailorbob's Avatar
sailorbob
Sorry, again I don't know the differences between your AGED ecu and the DARK ecu to be able to say if they can be swapped.
Old Mar 4, 2005 | 06:25 PM
cossy's Avatar
cossy
I don`t know the difference 2
Old Mar 4, 2005 | 07:11 PM
sailorbob's Avatar
sailorbob
Just had a quick look on the ATP Electronics site and they list the AGED ecu as 93 on and the DARK ecu as 98 on, looks even less likely for them being compatible.
Old Mar 5, 2005 | 08:58 AM
cossy's Avatar
cossy
So it`s not reccomended to swap the ECU`s?!
Old Mar 5, 2005 | 06:40 PM
SteveB's Avatar
SteveB
There are 100's of 4 digit codes on the Ford ECU's
Jay Racing
Ford Focus RS
Apr 15, 2009 09:42 PM
RsToy
Nov 12, 2004 07:51 AM
Exeter J
13
Sep 30, 2004 10:51 PM
James
11
Jul 27, 2004 09:59 PM
