Focus TDCi 03 starting problems
Old Dec 26, 2011 | 06:13 PM
MalteseFalcon's Avatar
MalteseFalcon
Default Focus TDCi 03 starting problems
I am having difficulties to start my Focus tdci especially in the morning, when I gave it 3 times heater it will start but else it won't. I have checked the glow pugs and all 4 are good as these were changed last winter. Is there any other problem regarding starting it up? Thanks a lot.
Old Dec 26, 2011 | 06:29 PM
pani_k's Avatar
pani_k
PassionFORD Member
Well if it needs 3 cycles of glowplugs I would assume that it is these you need to have a look at first. The fact the the plugs are fine and new may point out to a weakness in the plug circuit not giving them enough voltage.
Either that or perhaps the fuel pump is not priming properly.
Old Dec 26, 2011 | 07:22 PM
CraigJ's Avatar
CraigJ
just had this problem. turned out to be a fucked injector. was dropping the fuel pressure in the rail. pull off the leak off pipes from the injectors and get someone to crank the engine. i had 3 with bearly any fuel coming out and one that was jetting out.
worth a quick look.
Old Dec 27, 2011 | 04:16 PM
MalteseFalcon
thanks a lot, I will take it to the my friend John's Diesel service to have him take a look at the injectors and also check the voltage on the injectors.
Old Dec 31, 2011 | 02:26 PM
MalteseFalcon
The problem was coming from a tired battery. I fitted a 70ah Varta and now everything is fine. thanks.
Old Dec 31, 2011 | 03:25 PM
gouch1's Avatar
gouch1
glad to here its fixed
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Fordmad!
Sep 26, 2015 05:24 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
