Electrical problem
Old Dec 20, 2011 | 03:19 PM
Fordmad!'s Avatar
Fordmad!
Default Electrical problem
Car starts and runs fine. Then as soon as i put the lights on or indicators it cuts out.
I thought it was the earth off the battery so i took it off, cleaned it and re earthed it but no joy.
Took the battery off my van which is a new one tried that but still the same.
Altenator is newish done probably a 1000 miles or so, so i doubt its that.
Could it be another earth somewhere? Was going to clean and re earth them all anyway just too be sure but its gone dark lol
What else could it be...?
Cars an xr3i efi
Old Dec 21, 2011 | 07:14 AM
Fordmad!'s Avatar
Fordmad!
Anyone have any ideas....
Old Dec 21, 2011 | 05:26 PM
Fordmad!'s Avatar
Fordmad!
Any ideas lads...
Old Dec 21, 2011 | 05:38 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
earth behind dash id guess, or damp fusebox?
try earthing engine and body from battery
Old Dec 21, 2011 | 05:51 PM
RichieST's Avatar
RichieST
What happens if you give it some revs before turning the lights on? Does the car struggle then die, or just cut out?
Old Dec 21, 2011 | 06:58 PM
GVK.'s Avatar
GVK.
Does the battery light come on before you start it?
Does it go off when you start it?
Have you tried putting a voltmeter across the battery with it running to see if it's charging?
Alternator might be new but if it's got a wiring fault it won't work.
As above check engine earth and earth from battery to body (inner wing)
If no joy check earth points inside the car.
Old Dec 22, 2011 | 08:19 AM
Fordmad!'s Avatar
Fordmad!
Was hoping i wasnt going to have to take the dash out again
Will check everything else first before i do that!
Cheers!
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
