Dump valve
Old Dec 17, 2011 | 08:07 PM
marcus-rs2000's Avatar
marcus-rs2000
Default Dump valve
What am I doing wrong ? I fitted the dump valve and I teed into the pipe that runs from my gauge in the car and to the ecu but when the car is running it keeps on cutting out ! Any ideas thanks
Old Dec 17, 2011 | 08:50 PM
mk1turboestate's Avatar
mk1turboestate
is it the rite one for the car?
Old Dec 18, 2011 | 07:39 AM
Alvyn's Avatar
Alvyn
Ditto! what car is it??
Old Dec 18, 2011 | 11:13 AM
martysmartie's Avatar
martysmartie
What they said ^^, I suspect you have an ERST, if so they have a different type of they have a different type of DV, and you have the wrong one!
Martin
Old Dec 18, 2011 | 03:13 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Dont single piston ones not work correctly on a erst. Sure my mate bought one years ago as spares or repair and he blocked off the dv and hey presto perfect. tried it with a double piston and that worked just fine
Old Dec 18, 2011 | 05:59 PM
marcus-rs2000
The car is a series 1 rs turbo it's a baileys dv but not sure if it's a twin piston one when you rev it it makes the psst noise but on tick over it stalls ! It has a boost gauge running from the inlet manifold even when you disconnect it from there and run the pipe from the dv straight to the boost gauge still stalls
Old Dec 18, 2011 | 09:08 PM
martysmartie
As I suspected then with the car, they need a certain type of DV, you have the wrong type and have created an air leak which is causing the running problem!
Martin
Old Dec 20, 2011 | 05:57 PM
CosworthGuy
3dr Cosworth owner
As marty says. You need a bailey dv36 not a 26 that i suspect you have
Old Dec 20, 2011 | 06:40 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Bailey dv36 is also a twin piston but the venturi type and dv26 is also a twin piston, you more than likely are running a single piston dv24 which is used on the efi fiesta turbo's which is unsuitable for cars with an airflow meter like the series 2 rs turbo.
Old Dec 21, 2011 | 09:23 PM
Alvyn's Avatar
Alvyn
Take it off and if you look into the tube part if there's not a bar in the middle it aint no good for your car ie it's a single type!
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
