Fuel pressure
Old 17-12-2011, 11:20 AM
Shaun Wilson
Shaun Wilson's Avatar
Default Fuel pressure
Would i be right in thinking the fuel pressure should be 2.8 to 3.0 bar on my W reg mondeo 2.0 zetec blacktop and at which point in the fuel system would be best to check this, i have a power boost valve on with the gauge on it but would prefer to double check as i dont trust the gauge reading.
Old 17-12-2011, 12:29 PM
martysmartie
martysmartie's Avatar
I would ditch the "Boost valve" straight away!
Usually it's checked with a gauge at the rail, not sure on the pressure for your car but I should think what you said would be the very most it should be!
Sometimes the readings are given with the vacuum line disconnected as well!
Martin
timsrs
13-11-2018 11:48 AM
A.t.p
23-10-2015 07:54 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: Fuel pressure
