Zvh Compression ratio Problems...
Old Dec 9, 2011 | 11:31 PM
Bartheez's Avatar
Bartheez
Question Zvh Compression ratio Problems...
Hi there ...
I "hope" you can help me out here...?
I am building a 2 litre Zvh engine. Using a 2 litre Zetec silvertop bottom end, Cvh 1,6 Efi head and Focus Rs mk1 pistons...
I have been trying to figure out the compression ratio of this setup. But my math skills can not cope with it :-(.
So i have a theory. Please correct me if i am wrong...
Zetec std cr. = 9,6:1
Zvh with Std. Zetec bottom end cr. = 8,3:1
Focus Rs mk 1 std. cr. = 8:1
Wich must leave me with a cr. around 6,7....? Not exactly. As i am using the Cometic Zvh multi layer headgasket. I have forgotten the thickness of this one...
But this cr. is way to low if i am not mistaken? I am hoping to pull around 300 hp on this setup with a lot of fancy specs and a Garret GT2860RS turbo... But im not sure with this setup??? :-(...
Best regards - Kasper - Denmark
Old Feb 10, 2012 | 11:22 AM
Bartheez's Avatar
Bartheez
Default :-)
Upp Upp
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Chas
Oct 5, 2015 07:13 PM
Fezman1
Oct 2, 2015 01:22 PM
