24v cosworth Brain picking knowledge wanted
Old Dec 8, 2011 | 11:58 PM
Dom-hkl's Avatar
Dom-hkl
Default 24v cosworth Brain picking knowledge wanted
I have a 24v cosworth boa which i am used for a race xr4i as of next year im going up a class and will be needing around the 400bhp mark what i am after doing is putting one larger turbo on the back, i was told that the pistons have cut out for the valves is this true? or is that on the bob as i heard this was a week spot and the pistons under forced induction melted here ?
or in the boa are the pistons the same as the 12v cologne as i have seen on of these with a whole set running 500 bhp on standard internals
and any things people know to do with these engines would be muchly appriciated
Old Dec 9, 2011 | 11:28 AM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
im gona reply because i want to know this aswell lol
Old Dec 9, 2011 | 07:09 PM
opposite lock's Avatar
opposite lock
There is lots about these here
http://www.fordpower.org.uk/forum2/
I just scrolled down and found a nice saph with 24v turbo
Old Dec 9, 2011 | 07:19 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
try boost performance they have engines running in tvr race cars.
Old Dec 9, 2011 | 07:31 PM
JohnnyB's Avatar
JohnnyB
500 bhp will need a little piston work, standard pistons will be ok once machined, but they crack after a lot of abuse, so if your racing I would get uprated ones, boost performance first spec upgraded ones were not good, but I assume they have fixed the issue? or get some FBE forged pistons and do some work on them.
I would just go for a T4 with standard pistons keeping the boost to max 6psi, you should see about 320bhp on a good 24v
moesin2005
Jan 23, 2022 06:28 PM
marky_g
Aug 17, 2015 12:21 PM
Aug 14, 2015 07:29 AM
adriansaleem
Aug 3, 2015 11:21 AM
