Power steering into a 89 saph
have my 1.6 1989 sierra classic
no power steering with a2ltr pinto engine fitted
is it a big/hard/expensive job to fit?
anyone got instructions or a guide/equipment i need?
cheeRS lads
cheeRS lads
easy enough
what you need is a pinto donor, be it sierra or granada
you need to swap over the alternator bracket to the one with the power steering attachement, you've got to get the belts as they are longer as well and the pump
the pipes coming from the pump are specific to the pump but you can probably get some made up aftermarket
the racks are the same on all sierra's so a power rack is all you need
other than that it's a 3 hour job if you are unlucky as there are 4 bolts on the bracket and 2 bolts on the rack to undo
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
