Mondeo TDCi probs
Old Dec 8, 2011 | 10:52 AM
jonhunt85's Avatar
jonhunt85
Default Mondeo TDCi probs
Hi all little help.
2002 Mk3 Mondeo Zetec S TDCi 130bhp.
got car as a non runner and what the owner said happen looked like a glow plug prob. Old glow plugs not workin replaced and workin coil light stops flashing on dash.
Now we find there no fuel going to the engine.
Fuel filter looked new so took it off and filled it up with fuel but no fuel being pushed down the out pipe.
Have put some more fuel into the car incase it also has a faulty fuel display.
have plug a computer in and no faults shown.
any idea people, is it the fuel pump the last owner said he was driving it the coil light start to flash and it cut out that was it witch should mean glow plugs or relay.
any help be brill.
Going over it 2moro to try find what it is
Old Dec 8, 2011 | 05:21 PM
bailey1981's Avatar
bailey1981
Could be absolutely anything
the tdci engines are pure cack to be honest
i used to work as a fitter at 1 of the midlands top diesel specialists
the fuel pumps are problematic as is the injectors
but if theres no fault codes its a little strange
if i was you id give it a sniff of easy start to make sure it will run & its not something drastic
Has anyone else had a play about with it ?
Can you see all the dynamic parameters on the computer
your plugging it into ?
So you can check for sensors working etc
they can be a absolute twat to bleed up after the fuel pipes have been took off
Old Dec 9, 2011 | 06:31 PM
jonhunt85's Avatar
jonhunt85
tank sayin half a tank
last owner sayin he not replaced anything to don anything witch aint true cos air intake pipe was off and air box cover loose and fuel filter looks new.
check all fuses and relays all ok no faults shown up got some1 form work over the weekend to bring the fuel drain van over see if he can pull fuel up i think it just a air lock big one.
and i hope it all it is - A good suck
Old Dec 10, 2011 | 04:08 PM
jonhunt85's Avatar
jonhunt85
prob found Fuel pump in fuel tank.
anyone no if it is easy to fit as guy i had look over the car said it is tight and make sure you don't brake or snap any pipes in the tank.
any help or advice ppl
Old Dec 10, 2011 | 06:18 PM
forevaford's Avatar
forevaford
i dont think the tdci mondeo had a fuel pump by or in the tank
Old Dec 11, 2011 | 12:46 PM
jonhunt85's Avatar
jonhunt85
only a little one to push the fuel the the front of the car.
found a few for sale for the car Ł65 used and working.
Fit it in the week and fingers crossed it fixed.
Old Dec 11, 2011 | 02:48 PM
cossie.con's Avatar
cossie.con
Let us know the out come
cheers Mik
Old Dec 11, 2011 | 07:50 PM
bailey1981's Avatar
bailey1981
How many wires go to the sender unit
cos if its only 2-3 its not a purge pump its just a sender unit & you will be wasting ya cash replacing it
if theres 4 or more its worth a try
but im pretty sure mondeo tdci dont have electric pump in tank
try booting the tank from underneath as if its got a in-tank pump
& the motor is jammed this may free it off
we used to do this on pug hdi's as they are prone for in tanks going
id get a inline hand pump
commonly known as a bollock lol
connect it to the fuel supply pipe that goes before the fuel filter
Disconnect the suply pipe to the main fuel pump
then pump the bollock till fuel comes out the pipe at the pump
make sure all the air is out n its just diesel coming out
re connect the pipe to fuel pump but leave the hand pump connected
get a decent battery & crank the car over aswell as pumping
the hand pump
if its air locked this should get you running but sometimes
it doez take a while for all the air to come out the system
the common rail systems are a propper arse to bleed up
if it was a normal tddi you could do the same routine to bleed it up but leave the injector pipes loose till fuel shoots out them then nip them up n it would run
tdci are a bit different & ya not supposed to leave the injector nuts loose
altho if we had 1 at garage that was a tit to bleed we would do
Just dont stand anywhere near it as its a lot higher pressure on a tdci than a tddi
hope this helps you
or even someone else
if you was local to me i would of come n had a look
Old Dec 11, 2011 | 07:55 PM
gouch1's Avatar
gouch1
every time i see a post on here tdci is always followed by prob or problems
Old Dec 12, 2011 | 07:24 PM
jonhunt85's Avatar
jonhunt85
guy that come over and had a look at it said sometimes they just need a wack gave it a few with no luck and buzzing when key on and Power going down the wires (2wire) but no noise.
part be ere 2moro (Ł65) fit it Thursday or fri and will see.
Old Dec 18, 2011 | 02:26 PM
forevaford's Avatar
forevaford
i still dont think tdcis have a pump by or in the tank. i know the tddis do though
Old Dec 18, 2011 | 03:16 PM
jonhunt85's Avatar
jonhunt85
no they don't BUT pump is workin but fuel not going to it SO from the tank to the filter summin blocked it.
At mates workshop in the air avin a look at the pipes should no more Monday Hopefully.
Old Dec 26, 2011 | 06:07 PM
MalteseFalcon's Avatar
MalteseFalcon
when My focus TDCi did that I took it on the computer and it showed that the cam sensor was faulty. I replaced it and it worked fine till than....
Old Jan 6, 2012 | 03:32 PM
jonhunt85's Avatar
jonhunt85
Had a look over it and The fuel pump is pumping but no hard enuf to push the fuel into the injectors. bugger.
New fuel pump goin on should have it back Tue
thanks everyone for ya help.
Ya no fuel pump in the tank but had been told buy a few ppl sometimes it get clogs up and can stop fuel going up to the filter but was worth a try.
thanks everybody.
Old Jan 14, 2012 | 08:25 AM
jonhunt85's Avatar
jonhunt85
Might have it back 2day.
Fuel Pump fitted Tue Fuel getting to top of engine.
Injector No.4 pissing out faster then you can put fuel in ya car i was told.
New injector fitted.
Car runs and drives BUT was very ruf.
had a nose about and found the chain had jumped 4teath i was told.
so going to ajust and fit new tensioners at same time so if all went well Fri depending when parts turn up Should have car Back today if not Monday
Slowly getting there
Old Sep 11, 2013 | 07:02 PM
lewiseyers's Avatar
lewiseyers
newbee
Default what was your out come on this i have similar symptoms
hi buddy did you ever solve this problem as i have simular symptoms, is there a pump in the boot on a 2002 tdci, according to euro car parts and ebay there is cos they sell them..
hope you can help me
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
