rs turbo fuel problem.
Old Dec 7, 2011 | 10:13 AM
s2chris's Avatar
s2chris
Default rs turbo fuel problem.
ive run out of ideas and hopefully you tech's can help me out,i parked up at a mates the other day with no problems,went to start the car when leaving and it would turn over but not start up,1st i thought my fuel pump had stoped working,but ive tested the fuel pump straight from a battery and it spins,tested the wires to the fuel pump and theres no reading,i searched and found to check fuel pump relay,it still clicks and seems fine,my mate no's how to test relay and is coming round 1day to have alook,just wondering if theres anything else i could check.
any help would be great
Old Dec 7, 2011 | 10:39 AM
P 17eed's Avatar
P 17eed
When you turn the ignition on you should hear the fuel pump cut in
Old Dec 8, 2011 | 09:25 AM
s2chris's Avatar
s2chris
yeh mate it youst to,but now its not,the fuel pump works ive tested it,and the relay seems fine,but for some reason the wires sent no volts to the fuel pump,and i not sure what to check next.
Old Dec 8, 2011 | 10:51 AM
stevealien's Avatar
stevealien
10 Year Member
Still sounds like relay to me.
Take the pink plastic cover off it and hold the contacts inside together and see if it kicks in
Old Dec 8, 2011 | 06:38 PM
GVK.'s Avatar
GVK.
Or take the relay out and bridge out the connector to test it.
Old Dec 8, 2011 | 07:00 PM
P 17eed's Avatar
P 17eed
As said above, bridge the relay. If still no pump running check of you have voltage to it.
I had the exact same thing happen to me when I had my first s2 about 8 years ago and that was the relay.
Matt Baxter
Sep 16, 2015 08:30 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Bailes1992
Aug 16, 2015 07:14 PM
taylora1409
Aug 12, 2015 12:06 PM
