Electrical problem MK4 esc xr3i efi
Old Feb 20, 2005 | 03:22 PM
ogie1xr3i's Avatar
ogie1xr3i
Default Electrical problem MK4 esc xr3i efi
when i put headlights on engine stops, rear wiper comes on ,both indicator lights on dash come on and the two little white relays
at the back of the fuse box make a squealing sound.
also happens when i press washer jets also main beam light comes on on dash.
please help as i love my 3i and test is soon.
Old Feb 20, 2005 | 11:09 PM
Al Bags's Avatar
Al Bags
Hi ..
Sounds to me like it could be one of these...
Water in the Fusebox.... or
A damaged/burnt Column stalk switch assy (you been running high-power bulbs in it without relays?) .. or ...
Damaged wiring .. maybe got caught or pinched behind the dash somewhere between Stalks and fusebox underside.
Old Feb 20, 2005 | 11:10 PM
Al Bags's Avatar
Al Bags
You should also check all the relays/contacts (and fuses) for corroded blades
Kam B
Sep 24, 2015 10:40 AM
RSmark84
Sep 13, 2015 01:29 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
bassboy
Sep 10, 2015 08:54 PM
focus2351
Sep 9, 2015 09:33 PM
