Escort RS Turbo Brake Problem. HELP WANTED!!
Old Nov 22, 2011 | 06:31 PM
Stolton's Avatar
Stolton
Default Escort RS Turbo Brake Problem. HELP WANTED!!
Hi Everyone.
Currently have a Series 2 Escort RS Turbo which was running ABS.
Before i brought it, it had the ABS removed and fitted with all XR3i Brake Lines, Servo & Master Cylinder.
First time i tryed bleeding them was lots of air in the lines but soon got all the air out but pedal was still soft and spongy.
Check all the lines and rear cylinders which then i replaced as were leaky but its still doing the same thing.
Bleed them all spot on how your ment to bleed brakes but still the pedal is soft and spongy
anyone have any ideas?
Much Appreciated.
Old Nov 22, 2011 | 07:39 PM
fordsod's Avatar
fordsod
Default pedal is soft and spongy
Hello! Fault can be a master cylinder. One of the middle for sealing is perhaps the wrong way ....
jason_nike
Aug 18, 2019 10:53 AM
mgtkr1
107
Dec 6, 2016 04:23 PM
adriansaleem
Aug 3, 2015 11:21 AM
adriansaleem
Aug 1, 2015 09:28 PM
Old ford
Jul 31, 2015 06:50 AM
