boring engine swap
Old Nov 22, 2011 | 04:43 PM
redfez's Avatar
redfez
Default boring engine swap
Hi guys,im after a bit of advice.Weve got a mk 3.5 fiesta with the 1.3HCS rattler,and basicaly want rid of the engine.The body is in really good shape,with only a little patch on the arch neeeded,and im respraying it next year.Obviously wed love to stick a zetec into it,but its not going to be possible at the moment due to insurance,anyway.What i want to know is,what would be a easy-ish conversion,with around the same cc?Ive seen a decent price Endura E 1.3 engine,and read that the HCS and Endura E are virtually the same?Is this a decent engine or is it just a rattler like the HCS?Any engines you guys can suggest?thanks in advance
Old Nov 22, 2011 | 04:51 PM
Joshy's Avatar
Joshy
Dreamer
Identical engines mate. not worth changing until you can afford more CC'
Old Nov 22, 2011 | 05:52 PM
redfez's Avatar
redfez
Ahh ok mate,cheers,any ideas what causing the 1.3HCS in mine to overfuel?Its not too bad on a run,but around town and short drives its seriously overfueling!!Petrol is pouring down the throttlebody when its idling!!!
Old Nov 22, 2011 | 06:17 PM
lockie's Avatar
lockie
tried a new carb?
Old Nov 22, 2011 | 06:57 PM
Joshy's Avatar
Joshy
Dreamer
Originally Posted by lockie
tried a new carb?
A mk3.5 would be single port injection...
might be a faulty temp sensor, making the engine run constantly rich in warm-up mode... does it run quite hot?
Old Nov 22, 2011 | 09:43 PM
redfez's Avatar
redfez
Ya its a SPI,did think it was the temp sender keeping the auto choke on.But i tried bridging the wires to "fool" the carb into thinking it had warmed up,but it made no difference.
Old Nov 22, 2011 | 11:08 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Have you had it on a co2 meater at all?? To check that it is over fueling? Or are you gessing its over fueling because you can see the fuel going in? What does it run like? And black smoke at all?
Old Nov 23, 2011 | 05:33 PM
redfez's Avatar
redfez
it runs ok!quite rattly,i do adjust tappets quite regular.No black smoke,but the exhaust fumes reak of petrol,and emissions were off the scale on the meter.
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
