Motorsport developments BOV
Old Nov 22, 2011 | 04:10 PM
vahurix's Avatar
vahurix
Question Motorsport developments BOV
Hi,
is there some trick to get this open for service? Or just brute force needed ?
Thanks in advance!
Vahurix
Old Nov 22, 2011 | 04:17 PM
James @ M Developments.'s Avatar
the top will unscrew but they are tight, try using two pairs of oil filter grips, the fabric seatbelt material type.
Old Nov 22, 2011 | 04:42 PM
vahurix's Avatar
vahurix
Thanks for the reply!
I tried to screw it earlier, but didn't get enough grip. Fortunately a pair of leather gloves helped
The reason I'm peaking inside is, it's starting to open at -0.5...Bar of vacuum. This is is messing up the idle speed and also allowing the unfiltered extra air into system at cruise mode. Since it has been used for years now, I recon the spring is a bit tired. The idea was just to stretch it a bit. A rookie hope to fix it
The other question.. now, when it's open, I see that, there is quite amounf of lubricant. This should be clean instead, I think ? I recon the lube got there because of the oil leaking turbo.
Old Nov 22, 2011 | 06:59 PM
vahurix's Avatar
vahurix
Damn, tried to stretch the spring, but still nothing.
@ idle after some driving
http://www.youtube.com/watch?v=fhOw_...&feature=feedu
Is there some replacement springs available for this type?
The other idea.. coudn't I just add a washer there to tighten it up a bit?
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
