vw tdi misfire/wont run, now fixed **with pics**
Hi chaps,
A scan revealed my tdi recorded a misfire on cylinder 4, and i suspect it is upon a cold start up, as i get a thin sheet of blue smoke and it does run a little rought.
After a few seconds the mis goes, and 20-30 seconds later the smokes gone too. It really is brief, and not much of an issue, but it irritates me nevertheless.
Low compression - unlikely, as the engine is in a1 health, uses no oil and returns 60+ mpg and never smokes
Weak injector that clears
Dead glow plug
What do you think? I plan to run some injector cleaner through her and possibly swap the GP's, but i would be interested to hear your thoughts - particularly as time is at a premium at the moment.
Thanks guys
Tom
Dead glow plug
Thanks guys
Tom
What engine is it?
Modern diesels don't need to use their glowplugs, even in minus figures they only pop on for a few seconds. Not like old diesels.
Sounds like a slight air leak in that one injector? But I am unsure what would cause that?
Well it came to head on Saturday when it wouldn't run at all. It started and ran for 1min before i had to turn it off to speak with a neighbour, then nothing, just wouldn't run... Another scan revealed noo fault codes......... see pics below
You were (seemingly) very close on the air leak comment!
ARL - pd150 for those less familiar
That was also on the list of possibles, but hopefully this (below) was the cause.
Took off the EGR and what a mess!
width=500
....and it hasn't played up since, so fingers crossed!
width=500
Thanks for your suggestions chaps
Tom
width=500
width=500
Tom
Eigdoog
13-09-2015 05:46 AM
andrewmctiernan
08-09-2015 03:05 PM
