mondeo power boost valve
Old Nov 16, 2011 | 08:34 PM
Shaun Wilson's Avatar
Shaun Wilson
Default mondeo power boost valve
got my hands on a power boost valve with full fitting kit, now im going to fit it this weekend is there any real difference in acceleration and power levels , whats the safest pressure to set it at and is there any hidden gremlins after fitting it that will need to be tweeked. cheers
W reg mondeo 2.0 zetec (black top)
Old Nov 16, 2011 | 08:36 PM
botters's Avatar
botters
competant bodger
you will gain zero power from it. all it is, is an adjustable fuel pressure regulator its completley unnecesary and they have also been known to burst causing the engine bay to set on fire, my advice dont fit it
Old Nov 16, 2011 | 08:41 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
set it up at full power but remember to fasten your seatbelt and bring a spare pair of pants.
Old Nov 16, 2011 | 08:42 PM
botters's Avatar
botters
competant bodger
fucking lol
Old Nov 16, 2011 | 08:44 PM
Shaun Wilson
this doesnt sound good, has anybody else got 1 fitted,
Old Nov 16, 2011 | 08:48 PM
fuzzy's Avatar
fuzzy
they generally get slated over in bmw world for being linked to engine fires. ive no person experience of that though.
Old Nov 16, 2011 | 08:54 PM
Shaun Wilson
so theres a real posiability ive just wasted Ł120 then lol
Old Nov 16, 2011 | 09:00 PM
fuzzy's Avatar
fuzzy
Ł120? its a definate waste not a possability.
Old Nov 16, 2011 | 09:43 PM
Churtz's Avatar
Churtz
It's not a waste. I've run one on prev cars. You won't get a gain in power, but the main benefit if these is the chafing pressure rate. It will create the set pressure 1.7 times faster (iirc) than the standard one. You WILL notice improved throttle response from it if you set it up correctly.
Matt
Old Nov 16, 2011 | 09:44 PM
Churtz's Avatar
Churtz
Changing**
Old Nov 17, 2011 | 05:12 PM
Shaun Wilson
well it would appear theres light at the end of the tunnel, whats the best pressure to set it at,
Old Nov 17, 2011 | 06:02 PM
Churtz's Avatar
Churtz
Hmm, set to standard vehicle specs....and maybe try 1/4 of a turn higher from there.
Matt
Old Nov 17, 2011 | 06:16 PM
Chaz888's Avatar
Chaz888
should be ok to fit mate has used them for years on his cars As far as I know it boosts the fuel rail pressure so you get a bit more squirt for each injector opening but I think your car has adaptive fueling as part of the ecu setup which will try an negate the extra fueling it detects and dial it out.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
Bailes1992
Sep 3, 2015 02:17 PM
YODI
Aug 30, 2015 01:12 PM
jc1989rs
Aug 30, 2015 06:32 AM
