saph cossie 4x4
Old Oct 23, 2011 | 07:20 PM
spencer carter's Avatar
spencer carter
Default saph cossie 4x4
can any one help my 91 4x4 cossie pops and bangs and the rev counter goes ape when hard accelerating ive changed the crank sensor . phase sensor. group a coil. new plugs dissy cap and rotor arm but it still plays up has any one else had this problem if so please help many thanks spence
Old Oct 23, 2011 | 07:23 PM
ginner's Avatar
ginner
ure blowing the spark out on the plugs mate get some new ones in
Old Oct 23, 2011 | 07:25 PM
paul16v's Avatar
paul16v
Monte 087
Try a set of plugs, check or change the map sensor and the alternator.
Old Oct 23, 2011 | 07:34 PM
forevaford's Avatar
forevaford
i had this, it ended up being the 3 wireing plugs just above the rocker cover clipped to the bulkhead
Old Oct 23, 2011 | 07:47 PM
spencer carter
hi do you need to replace the wireing plugs mate or is it a caes of just unplug and clean up terminals
Old Oct 26, 2011 | 09:08 PM
Alvyn's Avatar
Alvyn
Originally Posted by spencer carter
hi do you need to replace the wiring plugs mate or is it a case of just unpluging and cleaning up terminals
has been known for people to cut the plugs off and solder the ends together! or if you feel lucky just try giving the plugs(more than likely rusty ends) a good clean!
Old Oct 27, 2011 | 10:50 PM
qad's Avatar
qad
call the master of cossie a ring joe @ gsmotosport he will help 07940 181847
Old Oct 30, 2011 | 07:04 PM
forevaford's Avatar
forevaford
i cut mine off and soldered then together, 3 years ago. no problems since
landaqmabba
Sep 15, 2015 07:16 PM
tib2220
Sep 14, 2015 12:33 PM
dojj
28
Sep 11, 2015 10:00 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Escortdriver1
Sep 6, 2015 10:12 AM
