Cosworth core plug fitting
Old Feb 17, 2005 | 02:30 PM
Mrs_Ricky_3dr's Avatar
Mrs_Ricky_3dr
Default Cosworth core plug fitting
Do you need to use any kind of sealant? Or just fit them dry?
Thank in advance
The rs 3dr's!
Old Feb 17, 2005 | 09:11 PM
b13nde's Avatar
b13nde
just clean up the block with some wire wool or sand paper get it spot less and put them in dry never had any probs some say put some sealant on but no need
Old Feb 17, 2005 | 09:13 PM
Al Bags's Avatar
Al Bags
The Factory fit them with a semi-hardening sealer (like pipe sealant)
That's what I used on ones I did before. I would also use a smear of Red Hermetite on flange type core plugs and edge sealing types before you wack them in.
Old Feb 19, 2005 | 04:44 PM
ricky_3dr's Avatar
ricky_3dr
Thanks guys All done and water tight
Old Feb 19, 2005 | 10:15 PM
Al Bags's Avatar
Al Bags
Nice one! Last ones I did were for an E-Type Jag for someone. Loads of the blighters
j.hammond1
30
Oct 31, 2021 05:28 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
COSWORLD
Aug 14, 2015 07:40 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
