rear spring removal on three dr?
Old Sep 17, 2011 | 11:42 AM
turblower's Avatar
turblower
Default rear spring removal on three dr?
just wondering the easiest way to remove the springs because im fitting coilovers?
thanks
Old Sep 17, 2011 | 11:52 AM
Weeksy's Avatar
Weeksy
Hi dude,
Unless your springs are ridiculously short, you will need to undo the driveshaft bolts on the hub end.
The spring then comes out bottom first, rearwards!
Enjoy
Weeksy
Ps you should have come to me for your coilovers!!
Old Sep 17, 2011 | 12:21 PM
turblower's Avatar
turblower
cheers mate,ill have a go doingg like that,wat coilovers have u got anhow much u want for them?
Old Sep 17, 2011 | 02:06 PM
Weeksy's Avatar
Weeksy
Pm sent.
Thanks
Weeksy
Old Sep 17, 2011 | 03:07 PM
martysmartie's Avatar
martysmartie
They are a nightmare!
As said you should remove the driveshafts (Haynes way), I however undid the diff and undid the beam one side and dropped the beam down, even then I still needed a small set of spring compressors. If you do this make SURE before you undo, make sure the diff is supported with a jack, then move the jack to the beam itself and let it down after removing the two guide plate and the beam mounting bolt.
I did try and undo the shafts but my torx drives arn't brilliant and they were very tight!
You will also need to un bolt the shock on the arm.
How people say you just undo the beam mount and shock I don't know, they must be very short springs!
If you have braided brake lines you also need to disconnect these, as you just can't remove the "U-clip" and unclip then from the underbody like you can with the flexys.
Martin
Old Sep 17, 2011 | 04:11 PM
adam151082's Avatar
adam151082
if your fitting coilovers just take a angle grinder to them and cut them in half
Old Sep 17, 2011 | 04:53 PM
Weeksy's Avatar
Weeksy
Haha, now that one I like!!
Love it dude! Especially some gaz shocks supplied by me- even better!
Thanks
Weeksy
Old Sep 17, 2011 | 05:03 PM
Mark RS's Avatar
Mark RS
Yep,angle grinder.
Old Sep 17, 2011 | 05:43 PM
john v's Avatar
john v
excuse my inexperience but when you fit coilovers on the rear do you totaly do away with the spring and is this the same on a 4x4 saph
Old Sep 17, 2011 | 05:51 PM
Weeksy's Avatar
Weeksy
Totally do away with the spring fella.
It typically uses a 1.9 id coil to keep it slim given the lack of space there with shallow shape to the inner wing originally only designed for a shock.
Thanks
Weeksy
Old Sep 17, 2011 | 06:09 PM
john v's Avatar
john v
thanks for that,it makes sense now cause i couldn't work out what the piont was having height adjustable coilovers on the rear when the springs dictated the height,its all clear now,that will be on my list of things to do,fantastic place this forum
Old Sep 17, 2011 | 09:09 PM
Weeksy's Avatar
Weeksy
More than welcome my good man.
Pm'd you fella
Thanks
Weeksy
Old Sep 17, 2011 | 09:17 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
grinder or gas axe takes 5 mins top lol
Old Sep 17, 2011 | 09:22 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if you don't want to undo the shaft, undo the beam mounts on one side and loosen the brake pipe and they should slide out
did it on mine easy enough
Old Sep 18, 2011 | 03:44 PM
martysmartie
Tried this on mine, both sides, near enough cleared the pan, but then there still is no way you can get it out , due to the bump stop, even with compressors. I undid the beam mount and the diff mount, but even then I needed compressors.
Martin
Aug 29, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
