Crossflow wont rev out
Old Sep 13, 2011 | 08:18 AM
McAutotester's Avatar
McAutotester
Default Crossflow wont rev out
Hi Guys, This is my first post on Passion Ford so bear with me.
I have a Dutton Kit car with a 1600 crossflow and a Weber DMTL carb that I'm using for autotesting. It starts and runs fine from cold but when its warm and its been switched off and then back on again it will only run at low revs. At high revs it just dies and doesn't seem to be getting the fuel through. I've changed the fuel filter and serviced the carb thinking it was dirt in the fuel but its still got the same problem.
Can anyone help??
Old Sep 13, 2011 | 09:04 AM
kev 3dr's Avatar
kev 3dr
Fuel line to near a heat source ?? Welcome to PF
Old Sep 13, 2011 | 10:20 AM
rs clint's Avatar
rs clint
insane
is your fuel delivery ok
Old Sep 14, 2011 | 02:48 PM
McAutotester
Fuel doesn't seem to be getting to the carb when the engine is hot (it works perfectly when cold) If I take off the air filter and look down into the carb there is no fuel being pumped in at high revs (it will idle OK). The Fuel line comes in from the back underneath the car but no major heat sources near it.
Old Sep 21, 2011 | 06:20 AM
kev 3dr's Avatar
kev 3dr
I pressume your running a electric fuel pump ??
Old Sep 21, 2011 | 10:31 PM
McAutotester
No, I don't think it is.
TPM961
Jan 15, 2018 10:50 AM
mondeomark
Sep 28, 2015 06:28 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
cozzy jeff
Aug 14, 2015 05:46 PM
