Ford ka 2010 indicator bulb replacement
Old Sep 12, 2011 | 04:18 PM
Jono 2173's Avatar
Jono 2173
Default Ford ka 2010 indicator bulb replacement
Hiy,Can anybody give me some advise,I want to replace my indicator bulbs for silver ones on a new shape Ford ka,on having a quick look,it looks like you have to remove the complete headlight unit,does anyone no different?
Old Sep 12, 2011 | 04:41 PM
RichieST's Avatar
RichieST
Have you looked in the owners handbook?
Old Sep 12, 2011 | 05:43 PM
Jono 2173's Avatar
Jono 2173
Yes looked in handbook,looks like some models you have to remove the complete headlight and some models you dont,looks like i'll be removing the headlights then,thanks for reply.
Old Sep 12, 2011 | 05:54 PM
martysmartie's Avatar
martysmartie
Some cars can be a complete nightmare! A Corsa being a prime example (So I have heard, I woulden't own one!)
Look behind the actual headlight unit, if you see any like spring clips then at least you know you don't have to remove body parts etc. This is the conventional Ford method, you then remove the panel and change the bulb behind, this sounds easier than what it is as access can still be tight by my experience on modern Fords!
Martin
Old Sep 12, 2011 | 06:14 PM
Hobomassiv's Avatar
Hobomassiv
This is the MK2 Ka based on the fiat 500 not the original.
The later MK1 Ka's had a panel on the wheel arch liner that could be removed to acess the headlight, you could check for this.
Alternatively go to a ford garage and ask them but dont get them to do it
If you are still stuck in a couple of days i can check out my parents Mk2 and see if i can work it out.
Old Sep 12, 2011 | 06:16 PM
martysmartie
I know, the year was the giveaway
Martin
Old Sep 12, 2011 | 06:33 PM
Jono 2173's Avatar
Jono 2173
Yes there is a panel,will look tomorrow but think there are clips behind which need removing,plus there's two screws on top of headlight unit,got a early ka 2.1 zetec area six wrc spec engine straight cut box,these indicator bulbs are on the side of headlight so access is easy,new ka are on the back of light so not so straight forward it would appear,thanks to all the replies.
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
RIB1122
Aug 12, 2015 08:51 PM
dlwarrior
Aug 5, 2015 10:19 AM
