Cosworth WRC header tank question......
Old Sep 11, 2011 | 06:48 PM
matman's Avatar
matman
Default Cosworth WRC header tank question......
does anybody know where I can get this fitting from??
Old Sep 11, 2011 | 10:41 PM
qad's Avatar
qad
try burtons power mate, all the best
Old Sep 12, 2011 | 12:38 PM
matman's Avatar
matman
Burtons dont sell it
Old Sep 12, 2011 | 04:04 PM
ian sibbert's Avatar
ian sibbert
The valve you have circled is a port used to pressurise the coolant circuit, they are made the same dimensions as a tyre Schrader valve TR4, any machinist should be able to make one in alloy for welding to a header tank (as per your pic) or you could buy an aluminium valve from somewhere like Merlin motorsport or Demon Theives and mechanically couple it to the header tank on a flat surface.....
http://www.merlinmotorsport.co.uk/p1...duct_info.html
Old Sep 12, 2011 | 04:07 PM
kev 3dr's Avatar
kev 3dr
why not just use a bolt in competion tyre valve ?? like ian has but in link (doh whish id checked link first !!)
Old Sep 12, 2011 | 07:28 PM
matman's Avatar
matman
Thank you for clearing that up
What would be the benifit of pre-pressurising the water system?
I assumed at first it would be used to vent any air or to de-pressurise the system before removing the lid or even to measure the pressure in the system.
Old Sep 12, 2011 | 07:55 PM
ian sibbert
Pressurizing the coolant allows the boiling temperature to increase and in turn improves the cooling efficiency....we run our system at 1.7 bar....
Old Sep 12, 2011 | 07:58 PM
massivewangers's Avatar
massivewangers
That's very interesting to know. How do you pressurise it? Just with a simple air line? I assume it's like a simple tyre valve type fitting?
J1mbo's Avatar
J1mbo
B1mbo
wow! Never knew that, pm on way Ian
Old Sep 12, 2011 | 08:36 PM
grcossie's Avatar
grcossie
My GGR tank, has this valve fitted
Old Sep 12, 2011 | 08:57 PM
matman's Avatar
matman
Ahhhhhhhh.
I remember that from my theory days at uni doing Mech Eng
I assume then that the expansion tank is filled to half level (or where appropiate) and then pressurised with air?
Do you set it to 1.7 bar by experiance or is it documented somwhere
Old Sep 12, 2011 | 08:58 PM
matman's Avatar
matman
any pics ??
Old Sep 12, 2011 | 09:21 PM
ian sibbert
Originally Posted by matman
Ahhhhhhhh.
Exactly, we bleed the system free of air and before competitive use pressurize with air...
It's gone on for many years in motorsport...there are other benefits...elimination of localised boiling etc etc.......
Old Sep 13, 2011 | 09:45 AM
grcossie's Avatar
grcossie
Don`t have any pictures of it, but it`s the same as the red one here, (mine is blue) whit an conections
http://www.grahamgoode.com/frpua2.htm
jessie_rs
11
Jun 3, 2019 04:57 PM
FlashRS
Sep 14, 2015 12:36 PM
mint_s2
Sep 2, 2015 08:58 AM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
