low boost
Old Sep 11, 2011 | 07:23 AM
55rsturbo's Avatar
55rsturbo
Default low boost
good morning does any one know why i now have 8 boost and befor i changed the turbo i was running 16 the turbo has been reconditioned no smoke or any slack ect so all good, i put another actuator on supposed to be good and it is a 31, would it be possible to get the pipes on the actuator and turbo round the wrong way or is the actuator dodgy maybe. i hope some body can throw a few ideas my way. many thanks for looking frankie
Old Sep 11, 2011 | 07:58 AM
RS 5tu's Avatar
RS 5tu
if you have put another actuator on your now running 8psi then the first this i would do is adjust the preload on the actuator.
Old Sep 11, 2011 | 08:49 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Yeah got to be the actuator setting I would have though.
Normal amount of preload is about half the the width of the hole that the pin goes through, but depends what yours was on when it was setup last of course.
Old Sep 11, 2011 | 04:10 PM
55rsturbo's Avatar
55rsturbo
thanks for that, put the old one back on and fine, will try the other one again because it is a 31 and i had it adjusted wrong, just rebuilt the turbo all is good. cheers frankie
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Tank Mike
Sep 26, 2015 08:07 AM
