esc cos timing
Old Sep 7, 2011 | 11:35 AM
scott-cos's Avatar
scott-cos
Default esc cos timing
hi can someone tell me the marks for setting up the timing on a small turbo esc cos as just did a full rebuild on it.
thanks scott
Old Sep 7, 2011 | 11:50 AM
martysmartie's Avatar
martysmartie
If ST is the same as the rest of the YB family, then you should have an arrow on each cam pulley, these should face each other. (This is only possible in the one and only correct position)
The crank pulley has a V notch, which I don't think yours will as it's EEC managed and will have a 36-1 affair, so this may not be true.
Also ST has WS if I am not mistaken, and thus it has no dizzy?
Martin
Rod-Tarry
237
Mar 18, 2016 09:13 PM
xrmalin
Sep 13, 2015 06:52 PM
Shows & Track Days
Sep 4, 2015 07:16 AM
hopper350
Sep 4, 2015 12:53 AM
y4n
Aug 17, 2015 12:12 PM
