removing wastegate arm from housing??
hello i want to remove the wategate arm from the housing.
i carefully ground the weld off the top and removed the top piece which connects to the acuator
then the wastegate arm dropped down but not enough room to get it out though
do u take out the sleeve inside the houing?
please help thanks
please help thanks
Si B
12-09-2015 06:49 AM
