Central locking problem ... most annoying!
Old Aug 27, 2011 | 03:27 PM
ThomasV's Avatar
ThomasV
Default Central locking problem ... most annoying!
Hi guys,
My Sapphire Cossie is playing up with the central locking system.
This morning when I engaged the alarm/c-locking the doors locked and then unlocked again.
The alarm engages fine and if I open the door (which SHOULD be locked but isn't) then it triggers the alarm.
Every time I engage it, it locks and then immediately unlocks again ... :/
Any ideas ? ... anyone tried this before and have some good advice ?
Old Aug 27, 2011 | 03:34 PM
Emblem's Avatar
Emblem
Sounds like a door lock is sticking, then thunking its not closed. Wd40 all door locks, then try it.
Old Aug 27, 2011 | 03:51 PM
ThomasV's Avatar
ThomasV
Hmm ... now that you mention it, I have had some problems with the boot-lock ... I'll check it out, thanx.
Old Aug 28, 2011 | 01:50 PM
martysmartie's Avatar
martysmartie
Exactly what he ^^ said, it will be one of the master locks that is sticky, i.e. the driver or passenger, when the C/L pulse times out, the offending one is "Stuck in the middle" so it simply reverts, lube both the locks and should be job jobbed
Martin
nico12
Dec 31, 2015 04:42 PM
Fudgey
Sep 17, 2015 01:06 PM
tib2220
Sep 14, 2015 12:33 PM
bassboy
Sep 10, 2015 08:54 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
