Why does my car only missfire under gradual acceleration???
Bit of a strange one this, or maybe it's an obvious answer I'm not quite sure?
Basically my saph is running great now but seems to have a missfire from 3rd gear onwards and only under gradual acceleration, i.e NOT if I am flooring it. If for example I start in 1st and nail it through all the gears foot flat to the floor its perefectly fine, but if i am sitting on the dual carriageway cruising and slowly and then accelerate in 3rd or higher it usually misses then carries on...... any ideas?
Location: Yarm (Teesside) previously from Fyvie (Aberdeenshire)
It could be plug related as I had a similar problem on my Audi S2 and it turned out to be a duff plug, but it was strange how it was only under gentle acceleration that it did it, you would think giving it full load in all gears it would have been worse.
