fiesta st
Old Aug 21, 2011 | 06:18 PM
GAZ345's Avatar
GAZ345
Default fiesta st
what is different in a fiesta st engine to standard 2L engine
Old Aug 21, 2011 | 06:26 PM
Dal_'s Avatar
Dal_
What "standard" 2 litre engine? The engine in the Fiesta ST is only used in the Fiesta ST in the ford range.
ST150 ENGINE (Also badged duratec ST)
Mazda developed engine actually called the duratec HE
is not a detuned version of the st170 engine.
chain driven double overhead cam
inlet manifold to the front
all alloy construction
in an st150
Old Aug 21, 2011 | 06:32 PM
GAZ345's Avatar
GAZ345
okay thats not good news then,mate has blew his up but has the chance of a 2L mondao engine
Old Aug 21, 2011 | 06:55 PM
simo2k2000's Avatar
simo2k2000
detuned ST engine is used in the 2.0 Mondeo isn't it? not sure on the differences although except the airbox is different. Possibly mapping as well
Old Aug 21, 2011 | 07:01 PM
GAZ345's Avatar
GAZ345
cheers,can anybody confirm this
Old Aug 21, 2011 | 07:15 PM
simo2k2000's Avatar
simo2k2000
Just done some digging...
The difference from the Mondeo to ST150 spec is the removal of the EGR valve, no swirl flaps in the inlet manifold and coil pack and HT leads on ST150. The Mondeo has coils on the plugs.
Old Aug 21, 2011 | 07:21 PM
GAZ345's Avatar
GAZ345
okay so mondeo will work,is cams throttle body ,valves all same
Old Aug 21, 2011 | 07:25 PM
simo2k2000's Avatar
simo2k2000
I'm sorry mate that's all I could find
Old Aug 21, 2011 | 07:27 PM
GAZ345's Avatar
GAZ345
cheers anyway thats helped a lot
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
