strange smoke from escort coss
Old Aug 21, 2011 | 09:38 AM
mickscossie's Avatar
mickscossie
Default strange smoke from escort coss
i am having a few probs with my big turbo escort when i start the car from cold no smoke same when hot but when driving at around 1800 to 2000 rpm i get a puff of smoke not blue more of a blacky blue same when been coasting down hill and accelerate again its only around these rpms any ideas it has good oil pressure and is not breathing or anything cheers mick
Old Aug 21, 2011 | 07:12 PM
mickscossie
i know im new on here talk about cold shoulder
Old Aug 24, 2011 | 07:09 PM
matcossy's Avatar
matcossy
valve stem seals maybe
Old Aug 24, 2011 | 07:23 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Yup, sounds like stem seals.
Old Aug 24, 2011 | 07:48 PM
Alvyn's Avatar
Alvyn
sounds like unburnt fuel to me(when was it last set up?)!if it was stem seals it would be blue m8 and mainly from cold start up!
Old Aug 25, 2011 | 07:39 PM
mickscossie
cheers for your replys im thinking fuel now im geting it set up on tuesday so will let you all know then thanks
Old Aug 27, 2011 | 09:59 AM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Black is usually fuel yeah. What mods do you have, if any?
Old Aug 28, 2011 | 10:03 AM
mickscossie
its running a stage 2 set up re mapped, uprated actuator uprated fuel pump full mongose exhaust system etc
Old Aug 28, 2011 | 11:55 AM
Takeshi's Avatar
Takeshi
If you get a puff of smoke out the back after accelerating from the over run, coming down a hill, then I'd suggest worn valve guides or stem seals.
Old Aug 30, 2011 | 02:05 AM
qad's Avatar
qad
sounds like over fueling to me give joe @ gsmotosport a call has he the best man for the job 0740 181847
Old Oct 17, 2011 | 06:50 PM
Alvyn's Avatar
Alvyn
wat was the outcome with your car?
Old Oct 20, 2011 | 11:04 AM
mickscossie
the result was a nightmare it had started to melt the piston on no4 so i had it rebuilt while in bits etc all good now done 500 miles running in feels good uses no oil or water and no smoke so good outcome in the end
Vincereese
Jun 1, 2023 09:14 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
