Starting/Immob Problem - Is it an easy fix?
Old Aug 19, 2011 | 06:14 PM
Gazz_'s Avatar
Gazz_
Default Starting/Immob Problem - Is it an easy fix?
OK, I have fitted a Focus engine into a Ford Ka.
I tried a test-fire once the engine was in and the engine was running fine with the Ka ECU.
I changed the ECU to the one from the Focus, and I also changed the Transponder as well, but now the engine will not start (even with the Focus key inside the transponder).
It almost starts but doesn't quite kick over like it did before.
Any ideas whats wrong?
P.S - Nothing else has been altered, just swapped the ECU over.
I am stumped!!!! All wires and connections are connected, etc... plenty fuel, battery is fine, etc.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
jc1989rs
Sep 18, 2015 07:05 PM
Cos500
Sep 16, 2015 09:50 PM
Flateric_2002
Sep 15, 2015 08:41 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
