help please :(
Old Aug 16, 2011 | 04:00 PM
rhysdavis's Avatar
rhysdavis
Default help please :(
so ive just fitted brand new brake discs and pads to my car then bleed the system twice and the brake pedal just goes straight to the floor, anyone know why? help would be appreciated
thanks
rhys.
Old Aug 16, 2011 | 04:16 PM
Churtz's Avatar
Churtz
How are you bleeding the brakes..with a 1man bleed kit or...? Also what car is it. Front or rear brakes?
And I presume you've tried pumping the pedal?
Matt
Old Aug 16, 2011 | 04:19 PM
rhysdavis's Avatar
rhysdavis
im using the 1 man bleeding kit yeah and its a fiesta xr2i just the front brakes
rhys.
Old Aug 16, 2011 | 04:28 PM
Rst tyrone's Avatar
Rst tyrone
zetec turbo
sometimes when pushing the piston back in the calipers it can reverse the seal in the master cylinder was it ok before you fitted the new brakes
Old Aug 16, 2011 | 04:49 PM
rhysdavis's Avatar
rhysdavis
was fine before i fitted the new ones yeah, what could i do to fix it?
rhys.
Old Aug 17, 2011 | 04:37 PM
rhysdavis's Avatar
rhysdavis
Anyone?
Old Aug 17, 2011 | 08:20 PM
martysmartie's Avatar
martysmartie
Exactly as said above, it sounds like you have 'Flipped' the master cylinder seals. This is why I bleed at the same time as I rewind the piston, so the pressure is not being reversed, this is what Haynes etc recommend as well.
If it is this, you have no option but to dismantle the master cylinder and relocate the seals, so far as I know.
Martin
Old Aug 17, 2011 | 08:22 PM
RichieST's Avatar
RichieST
If the brakes were fine before, why were you bothering to bleed them?
Old Aug 17, 2011 | 08:29 PM
Rst tyrone's Avatar
Rst tyrone
zetec turbo
either renew the master cylinder or dismantle. when pushing pistons back i always open the bleed nipple i learnt the hard way as i flipped a seal in an amg merc and had to fit a new master cylinder at a cost of Ł380 pounds
Old Aug 18, 2011 | 02:54 PM
rhysdavis's Avatar
rhysdavis
okay cheers guys will try that now
Old Aug 18, 2011 | 06:04 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Think i may have done the same when fitting new discs and pads.
Pedal is rock solid as normal if you press it hard, but if you press very lightly it'll eventually end up on the floor.
Was absolutely fine during track session at ford fair too, but had gotten slightly worse in the couple weeks after it started. Where's best for a rebuild kit?
Old Aug 20, 2011 | 06:16 PM
Focus_2008's Avatar
Focus_2008
Steve_2009
AstoN_B, I work for a car smallish accessories company & no company do any repair kits for Master Cylinder anymore unless there maybe anything on ebay but I doubt it
Old Aug 20, 2011 | 08:02 PM
AstoN_B's Avatar
AstoN_B
i know BigRed do caliper rebuilds/kits for most fords old n new. Might see if they can do master cylinder kits too.
Old Aug 21, 2011 | 04:09 PM
Focus_2008's Avatar
Focus_2008
Steve_2009
Ahh do they? Mite be worth bearing in mind then
