T34 turbos??
Old Aug 9, 2011 | 07:34 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
Default T34 turbos??
is the only difference between a T34.48 turbo to a T34.63 turbo just the exhaust housing? i thought turbine wheels were larger also?
cheers
Old Aug 9, 2011 | 07:37 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
nope swaped mine over last week just the housing size the wheel is the same size
Old Aug 9, 2011 | 07:42 PM
saph cos rob
swindon rsoc
thanks for the reply! what i dont understand is how just the housing can make the difference, i thought it would be the turbine wheel being bigger is what made the turbo laggier?
Old Aug 9, 2011 | 07:45 PM
clarke5700's Avatar
clarke5700
tbh i dont 100% under stand this my self the only difference i could spot was the .48 and the .63 stamped in the housings
Old Aug 9, 2011 | 07:46 PM
BigErn's Avatar
BigErn
Just the housing.....
Look at it this way, the 48 is a smaller hole than the 63. The turbo will take a more time to build the pressure if the air escapes through a bigger hole than it does a little hole.
Make sense??
Old Aug 9, 2011 | 07:49 PM
saph cos rob
swindon rsoc
yep that does ern! how much laggier is the 63 housing or is there not much in it?
cheers for the replys guys
Old Aug 9, 2011 | 07:52 PM
BigErn's Avatar
BigErn
Theres not massive amounts of lag difference tbh. The T34 is a great turbo and if you want it in the middle then theres a .55 housing too.
Old Aug 9, 2011 | 08:23 PM
Staffi's Avatar
Staffi
Yeah Ern's right there, i like alot of us on here have had the 48 55 and now my current 63, if i'm being totally honest my old 3dr on a NMS Live Map with the .48 housing on was probably the best road cossie i've had for pound for pound punch & fun, the .63 pulls harder than the .48 but alittle lazier at doing so, BUT not dreadful lag as somw will have you think..
Old Aug 9, 2011 | 09:36 PM
BigErn's Avatar
BigErn
IMO if you're on greens then go for a 48 or 55 but if you're going bigger, like greys, then go for 55 or a 63.
If you're on greens but are thinking you may possibly one day go greys then go for a 55
Rsmat
63
Sep 25, 2015 12:11 PM
28
Sep 8, 2015 07:10 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
