Clutch Ratchet
Old Aug 4, 2011 | 12:11 PM
rst-ste's Avatar
rst-ste
Default Clutch Ratchet
This bloody car is doing my head in!
The clutch bite was through the floor on my mk4 escort. I put a new ratchet kit on, which turned out to be one of the most stressfull things i've ever done in my life & its exactly the same
After further inpection, the ratchet appears to always be one tooth out. If I press the pedal down slightly & then push the back of the quadrant round (cable towards back of car) then the ratchet clicks into place where it should be & it goes into gear no problem. As soon as I take my foot off the pedal the quadrant goes back to the same stupid position!
When I lift my foot & the pedal raises, there is a flat metal flange at the top of the pedal box that moves the pawl up & releases the quadrant (this is when it goes back to being one tooth out).
Is the problem the tension in the spring between the quadrant & pedal? Has anyone ever had this problem?
Old Aug 4, 2011 | 04:03 PM
rst-ste's Avatar
rst-ste
Problem solved...mk5 pedal conversion needed due to ap clutch
Old Feb 28, 2012 | 02:41 PM
Yura's Avatar
Yura
Is it possible to upgrade clutch ratchet of 2wd sierra cosworth? Because after high revs I have a problems with ratchet - it adjusting by itself and impossible to change the gear.
PS all teeth of ratchet is ok. Is it possible to replace the pedal to mk5 escort?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
