diff & hubs
Old Jul 31, 2011 | 11:26 AM
cossydave377's Avatar
cossydave377
Default diff & hubs
im after some info please guys
im building a kit car and it uses sierra hubs.
i want to use granada hubs as im running 5x114.3 wheels (nissan) and will use wobble bolts
so am after info to do such job.
also it uses a 7" diff but hasnt got a lsd.
im looking at buying a 12v automatic m reg granada for the wheel hubs etc and also for the diff but im not sure what ratio it uses.
can you help there as well please?
i know its not a lsd but im going to buy a quife as every lsd ive had on other cossies etc has always been a bit open for my liking and i drove a quife lsd in a xr4i mk1 and loved it.
Old Jul 31, 2011 | 12:13 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if you want a granada to get the bits from with "standard" ratios then you need to buy a pre 94 car
your potential purchase "should" have the 3.64:1 diff, same as the 2wd cossie and it "should" come with a 7.5 inch diff
if you want a 7 inch lsd then you would need to find an xr or cossie 4wd rear diff which are all interchagable and will fit in the same beam you are thinking of using
Old Jul 31, 2011 | 12:25 PM
cossydave377
im a dick
i meant 7.5" sorry mate
ive got a 7" welded diff with bolt in shafts i was trying to fit and it didnt fit
what does the 4.. and high 3.97 etc diffs come from?
i know that a 3.77 comes from a scorpio cosworth as i had one of those
as said im not bothered about a lsd as im going to go quife
dosnt the m reg hubs fit in place of sierra hubs?
Old Jul 31, 2011 | 12:27 PM
dojj's Avatar
dojj
the granadas only came with 3.36, 3.62 and 3.64 diffs as far as i'm aware, the sierra diffs were also available in 3.92 as a 7.5 inch size
the granada hubs will replace the sierra ones no bother as they are the same other than having more holes in them for the studs
Old Jul 31, 2011 | 12:31 PM
cossydave377
this is the kit car
http://www.agmsportscars.co.uk/agm_s...cars_2_003.htm
mines not even nearly finished yet but you get the idea
it uses rover modded 3.5 V8, LT77 box, sierra rear diff and shafts, sierra hubs all round, cut in half and shortened steering rack!! yea i thought it was odd too!
basicly its a locost chassis with outriggers and a massive fibreglass shell bolted on
looks good IMO
should go well 220bhp and 750kgs
but sounds AWSOME
Old Jul 31, 2011 | 12:32 PM
cossydave377
blimmy which sierra came with a 3.92? 7.5"
auto?
Old Jul 31, 2011 | 12:56 PM
dojj's Avatar
dojj
auto?
every dohc injected car between 90 and 92
Old Jul 31, 2011 | 03:33 PM
My mk1 sierra auto 2L had a 3.38 diff as I sold it to a kit car chap, for the bike engined kits they're well sought after.
Old Jul 31, 2011 | 03:35 PM
this is the kit car
looks good IMO
but sounds AWSOME
It's a pity the mega slow changing Lt77 won't change fast enough, it's a seriously slow box, you must have a lot of mods for 220bhp from a 3.5, what's done to it ?, they produce good torque rather than bhp.
Old Jul 31, 2011 | 06:50 PM
cossydave377
Wink
yea i know i was going to put a ls2 in when it comes up at the right time.
loads run 2wd cossie 280-380bhp, v8 rover 150-300bhp and there is a v12 AMG approx 550-650bhp engined one being built as well
my engine is over bored to nearly 3.7, high lift cam, rhodes, webber 500 carb, inlet manifold, tubular headers,only 1 exhaust silencer per side, v.mild head work, and an electric fan.
220bhp is what ive been told, but i had a 3.5 same spec and it made 174bhp@wheels this is a pretty much standard tuning setup that people go for and get around 175-180@wheels, i was going to get a turbo-ed 3.9 with nos running a genuine 376bhp but the rover engine is made of chocolate and is more unreliable than a YB running 400bhp on 4 greens
im going to get it up and road worthy then get used to the rover and get a ls when the time is right, ive got so many other projects at present and need to concentrate on getting some completed
Old Aug 1, 2011 | 08:04 AM
I think you're using a over reading rolling road, not dyno dynamics is it ?
I've got a 4.6 ford modular V8 for sale complete with all ancillaries, was intended for a rear engined kit car(GT40) and a gearbox/transaxle the same as ascari use, that was £31K new for sale also, if interested!!
Old Aug 1, 2011 | 05:51 PM
cossydave377
220bhp (flywheel) isnt a lot over what id EXPECT given the mods, rover v8's respond quite well to headers and a cam, the webber just makes it all work. id expect that lot alone to make 180min and 210-220max
the 3.5 make 150bhp on twin su carbs, cast manifold and standard exhaust and cam.
v.v mild cam and injection they made 190bhp
im after an ls3 if and when the time is right, i want to see around 450-475bhp NA
Old Aug 1, 2011 | 07:32 PM
Injections never made 190, despite the hype, same with the 4.6 power, and the reason why RR/LR were actually prosecuted in the states, for woefully misleading figures.
You get the same bullshit figures from TVR, way way off the mark from quoted power on the RV8.
Old Aug 1, 2011 | 08:59 PM
cossydave377
i was going on this table from mez
Engine Size 3.5 3.9 4.2
Just A cam 185BHP@5500rpm, 210lbft@4000rpm 205BHP@5200rpm, 235lbft@3800rpm 220BHP@5000rpm, 250lbft@3700rpm
Cam And Flowing 210BHP@6000rpm, 230lbft@4000rpm 225BHP@5700rpm, 250lbft@3800rpm 240BHP@5500rpm, 270lbft@3700rpm
Plus 10.5:1 C/R 215BHP@6000rpm, 245lbft@4000rpm 235BHP@5700rpm, 265lbft@3800rpm 260BHP@5500rpm, 285lbft@3700rpm
Plus Big cam and trumpets 265BHP@6300rpm, 255lbft@4900rpm 275BHP@6000rpm, 275lbft@4800rpm 290BHP@5800rpm, 290lbft@4700rpm
the rovers not a great engine but its in the car and there is loads to do before i swap it for a ls engine
as the saying goes ' it'l do for na' LOL
Sierrasideways
Oct 8, 2015 06:37 PM
Iain Mac
Sep 30, 2015 09:39 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
