Please help
Old Jul 21, 2011 | 08:32 PM
chris1987's Avatar
chris1987
Default Please help
i want to do a project out of my fiesta but i think its way to slow since having an st170
So...Other than the 1.7 route (been done to many times) and i like to be different.
What engine (2.0L Wise) can i get that wont take that much time or money i dont mind spending money if its going to work.
I was thinking the 2.0l focus zetec engine or rs2000 DOHC Block has anyone gone down this route.
If so...
What price did you get the custom made engine mounts for maybe they fitted straight into standard ones?
What gearbox or again did it fit on to the fiesta mk5 box?
What ecu have i got to use (no aftermarkets to expensive)?
have you got to wire all the lights up again?
What engine other than the 1.7 would people recommend?
Any help on this will be great so i can get to the bottom of it get what i need and hopefully get it done.
Im a ford lover and hate being showed up by these nasty VTS'S lol
Old Jul 21, 2011 | 08:37 PM
hogdog's Avatar
hogdog
ST150's 2.0 Duratec is supposed to be easier to fit than the zetec. It's also very easy to tune in N/A mode up to 200bhp or you could fit a Jamsport supercharger kit for 3-400bhp depending on spec.
Old Jul 21, 2011 | 08:40 PM
chris1987's Avatar
chris1987
Thanks for the reply mate
Were can i get engine mounts made up and how much will i be looking at?
I will need the lot wont i engine gearbox looms ecu ect (the lot)
Old Jul 21, 2011 | 08:44 PM
chris1987's Avatar
chris1987
How much can i get the mounts made up 4 and were?
Will i need the lot aswell engine gearbox ecu looms ect?
Thanks
Old Jul 21, 2011 | 09:48 PM
hogdog's Avatar
hogdog
I'm really not sure to be honest. I'm a Focus owner, just something I'd heard. I've seen it done a couple of times before and I think there's a company that specialises in this kind of thing but I can't remember the name right now.
Old Jul 21, 2011 | 10:19 PM
chris1987's Avatar
chris1987
Just found a rather handy guide lol
Right this seems to get asked a lot on here so...
in order to fit a Zetec-E engine into a Zetec-S
firstly source your engine, personally stick in the 2.0 or its not worth it
then you will need to do the following to the engine
Fit Escort/Fiesta 1.6/1.8 Sump and oil pick-up pipe
Fit the Escort/Fiesta water pump (as it spins the opposite way)
Fit the Escort/Fiesta Flywheel as the 2.0 won't fit within the BC/IB5 bellhousing
Fiesta RS Turbo Clutch will fit and can be used for paddle clutches etc
Fit Escort/Fiesta Inlet manifold as Mondeo one wont fit
Use a CVH alternator Bracket and alternator but swap the Multi-V pulley off the original
zetec alternator onto this
thats the basics sorted for the engine
in order to fit into the car you will need a custom engine mount
the Zetec block will mount up to the Zetec-S IB5 (either straight up or with a Ka 1.3 bellhousing)
the block may need some of the fins removing dependant upon starter position but is easily done
retaining the original box allows the use of all original mounts and driveshafts
IF wishing to retain powersteering then custom pipes will have to be made from Rack to pump
otherwise fit a non-ps rack
coolant piping will have to be custom but is easily sorted
wiring wise it would be simple to add a mk3 16v fiesta loom and Ecu and piggyback it to your existing ecu similar to the omex installations in
Zetec-S
best obviously would be to run it from an omex, allowing for easier future modifications/adjustments
if wishing to run the original dash then the above wirings piggybacked to the original ecu will have to be used
if using an aftermarket dash a non-piggybacked system can be installed
a short oil filter from a CVH or a tiny filter from a Renault 5 Turbo will be neccasary for clearance
i think that covers the main of what is needed and as i think of more i will update, i hope this answers a few questions
inspiration for you boys
