16 cvh wont start when hot
Old Jul 12, 2011 | 02:48 AM
scooby-KILLER's Avatar
scooby-KILLER
Default 16 cvh wont start when hot
as titled i was wondering if any 1 would know the reason for it not to start when hot??
any help welcome thanks
s-K
Old Jul 12, 2011 | 12:04 PM
martysmartie's Avatar
martysmartie
Depends what you define by non starting? If it won't turn over then I suspect the starter is suffering from heat soak which is a common problem due to the close proximity of the exhaust manifold and the starter.
Martin
Old Jul 12, 2011 | 04:53 PM
chris m1's Avatar
chris m1
Check out this place, plenty of ideas
http://mk4escorts.freeforums.org/hot...-t11.html:top:
Old Jul 12, 2011 | 05:18 PM
darrenb16two's Avatar
darrenb16two
Starter motor if it's not spinning over as said above
Old Jul 12, 2011 | 05:46 PM
teamfatboy's Avatar
teamfatboy
Frog Tosser
Common fault is a bad earth not starter, try replacing battery to starter cables
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
StephTell
Sep 2, 2015 06:31 PM
kevin36
Sep 2, 2015 06:24 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
