coil pack conversion
Old Jul 5, 2011 | 02:45 PM
cozi500's Avatar
cozi500
Default coil pack conversion
Hi all anyone tell me where i can get a set of plug leads from for my Escort RWD running a c20let engine, its running a stand alone ecu with a ford coil pack, ive tried the mondeo plug leads but are to fat to fit in the plug holes, and not quite long enough.
Old Jul 5, 2011 | 02:52 PM
Is it a generation 1 coil pack or generation 2 ?, 1 has "clips" each side of the leads that help hold on to the pack, and are short and fat, 2 are taller and thinner and straight not using the clip arrangement.
Either way a bit pricey but Magnecor do custom made leads, can down load a quotation form from the website.
Old Jul 5, 2011 | 03:09 PM
cozi500's Avatar
cozi500
Yes have the clips fitted, just uploaded all my mapp and calibrated all the sensors ready to start it and dam the plug leads wont fit, must be the gen 2 ones then, will get a quote from magnacore aswell cheers
Old Jul 5, 2011 | 06:26 PM
Cheaper to get a new ford coil pack, than change the HT's, about £40 for a CP from ford I believe or you could use the Accel CP 140018, 100% straight fit in place of ford one, mine cost me about £45 inc taxes from usa spares, wymondham, norfolk.
Old Jul 5, 2011 | 06:34 PM
cozi500's Avatar
cozi500
Have been told that you can use granada cosworth ones, they fit ok and work well, not tried this as of yet just need to get as much advice as poss
Old Jul 9, 2011 | 07:24 PM
cozi500's Avatar
cozi500
granada cosworth one were perfect for the job cheers
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
