ka reving when clutch is down
Old Jun 24, 2011 | 07:19 PM
howie1989's Avatar
howie1989
Default ka reving when clutch is down
Hi my friend has ka and everytime she engages the clutch it revs its arse off. I know its a common prob but i don't know where to start help would be lovely
Old Jun 24, 2011 | 08:30 PM
RichieST's Avatar
RichieST
Idle control valve or quite likely a vacuum leak somewhere. Check all vacuum hoses for splits.
Old Jun 26, 2011 | 12:02 AM
howie1989's Avatar
howie1989
But its doesn't do it every time and only revs when's clutch is engaged
Old Jun 26, 2011 | 10:39 PM
ray barker's Avatar
ray barker
i think you will find the clutch is shaged you can test this by putting car in 3rd gear or 4th if hand brake is shit pull hand brake up as far as will go try to slip clutch with quite a bit of revs but not to much if clutch is good it will stall if it revs its arss of 200 quid should see you rite in most garages with new clutch
Old Jun 26, 2011 | 10:45 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
im trying to work out your wording (me bein a spaz with english lol) do you mean when shes driving the revs rise but the car goes no where? or when she puts her foot on the clutch it revs up?
Old Jun 26, 2011 | 10:55 PM
howie1989's Avatar
howie1989
i'll have a look probs tomoz i don't think the clutch is shagged as it's not noticeable i'll see tho u know these female drivers it only revs hard when she puts her foot on the clutch and that will shag the clutch eventually. the car has only done 40,000 on a t plate sooo could be needing it's first clutch
Old Jun 26, 2011 | 11:02 PM
clarke5700's Avatar
clarke5700
if the clutch is depressed when its reving it will not affect the condition of the clutch at all. sounds like its the idal speed control valve. what year is the car?
Old Jun 27, 2011 | 07:52 PM
ray barker's Avatar
ray barker
Default ka rev
sorry idid not read prop thought you ment when clutch wasnt engaged engine reving up under load
Old Jun 27, 2011 | 07:59 PM
clarke5700's Avatar
clarke5700
thats what i was trying to work out lol
Old Jun 27, 2011 | 08:06 PM
Escow-Van's Avatar
Escow-Van
Does it do the same in neutral as when the clutch is disengaged?
I can only guess its an air leak somewhere on the engine side of the throttle body or the throttle is not closing properly.
The revs can't climb without extra air getting in, that's my theory
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
