Efi turbo
Old Jun 22, 2011 | 05:03 PM
rsbolts's Avatar
rsbolts
Default Efi turbo
Hi just converted my rs turbo to efi all wired up new crank sensor but will not spark eny help would be great
Old Jun 22, 2011 | 05:10 PM
xrmalin's Avatar
xrmalin
My mate had this when he converted his 2i to turbo power and it turned out there is diffferant length holders for the crank sensor and his was too long so the sensor was too far away from the flywheel and not picking up. We changed it for a shorter one and bingo away she went your problem could be the same
Mark.
Old Jun 22, 2011 | 05:19 PM
rsbolts's Avatar
rsbolts
Hi wot did you change the sensor m8 as it just goes threw the blok on mine no holder
Old Jun 23, 2011 | 07:04 PM
ChrisH's Avatar
ChrisH
So, are you runnng a seperate ignition module? Or still on distributor?
Old Jun 23, 2011 | 07:14 PM
rsbolts's Avatar
rsbolts
Hi full efi convirshion on coil pack checked my crank sensor today and it's 13m short of the fly wheel been told theres 3 size sensors so hopefully the biger sensor is going to do the job.as the one I have is 40m and need the 52m one
Old Jun 23, 2011 | 08:25 PM
ChrisH's Avatar
ChrisH
That would do it, so there is no fueling either?
Old Jun 23, 2011 | 08:41 PM
rsbolts's Avatar
rsbolts
No m8 pump primes thou so hopefully she work with right size sensor
Old Jun 23, 2011 | 08:49 PM
ChrisH's Avatar
ChrisH
No hopefully about it, it will.
Old Jun 26, 2011 | 09:18 PM
rsbolts's Avatar
rsbolts
Started up first time with right sensor lol am now after a chip wot plugs in to back of ecu if eny one nows were to get these please
Old Jun 27, 2011 | 11:30 AM
ChrisH's Avatar
ChrisH
I'd only got for a Superchips one but, i don't know where you can get them now.
RSmark84
Sep 13, 2015 01:29 PM
bigryrs
Sep 7, 2015 06:45 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
