Air con knocks off at blower setting 2
Old Jun 12, 2011 | 10:30 AM
gph2000's Avatar
gph2000
Default Air con knocks off at blower setting 2
My Aircon only works at blower setting 1 (2002 mondeo 1.8 petrol). Any ideas why?
Old Jun 12, 2011 | 11:12 AM
COLEYST200's Avatar
COLEYST200
is the fan under the bonnet work
Old Jun 12, 2011 | 11:40 AM
dojj's Avatar
dojj
Resident Wrestling Legend
what do you mean "only works at setting 1"?
you mean the fan in the blower or the air con stops working after pos 1?
Old Jun 12, 2011 | 04:37 PM
gph2000's Avatar
gph2000
Default Air con at 1 only
Yes. The Fan continues to operate thru settings 2 - max, but the aircon is only operates at 1, so on a warm day I am constantly flicking down to 1 to get that distinctive 'bite' an up again. I does blow cool air, but on a hot day its nowhere like conditioned air.
So in terms of the fist answer, yes I believe the fan is working - unless aircon and cool air have seperate fans.
Old Jun 12, 2011 | 07:21 PM
Churtz's Avatar
Churtz
Sounds like control unit failure.
Matt
Old Jun 12, 2011 | 08:32 PM
RichieST's Avatar
RichieST
Does the light turn off then after setting 1? Sure it doesn't just need a regas? The engine cooling fan will run all the time when a/c is on.
markk
Sep 9, 2015 08:11 AM
3doorcozmess
Sep 7, 2015 01:32 PM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
Cragrat
Sep 2, 2015 08:25 PM
