2.0 Blacktop Turbo Questions
Hi all... Im new to the forum, but mainly new to fords!!
Ive been doing engine conversions for a few years, but mainly on the vauxhall scene with the good old redtop novas etc...
Had a bit of a laugh with a c20xe redtop and a fiat seicento with a mate from here, which made the practical performance magazine...
After looking at a few retro fords, im interested in getting something fun to tinker with, although im not clued up on the ford scene...
Im looking at building a 2.0 Blacktop turbo engine and fitting into a mk2 fiesta..
As im in the process of looking for parts, ive found a loom and ecu (ofac) at quite a good deal, however the loom is without the EDIS...
As far as i know this edis thing, controls the spark somehow, but will any ford edis do... or do i require one from the FRST to match the loom/ecu i have.
Finally looking at the differences between the ofac and ofab ecu & Map sensor... as fas as i can tell, the ecu im interested in is limited to 1.1bar boost...
Im intending to run a t3 turbo, with the ofac system and looking to only run a moddest 230-250bhp.. will this be possible? I was told a compression ratio of 8.5:1 would achieve around that figure @ 11psi.. Can anyone confirm this? And would a plate & gasket achieve close to this, or will it be way out?
Looking at the route of a decomp plate and single headgasket conversion (if i cant source some let pistons in the mean time...)
Has anyone used the early c20xe pistons in the turbo conversions? They are forged items with a little dish, although differ to the c20let ones slightly.
Sorry for these questions, however i cant find this info within the guides etc...
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
JoeyBoyden
18-08-2015 10:52 PM
