difficulty starting s2 rst
Old Oct 29, 2003 | 10:10 PM
IANS2RST's Avatar
IANS2RST
Default difficulty starting s2 rst
my rst does not start well from cold turns over for about 30 secs before it catches and needs plenty of throttle.
so far I have changed dizzy, leads, plugs, cap, rotor arm, fuel pump relay and the metering head.
The strange thing was when I fitted the metering head it fired straight away but after switching off the problem came back.
Once it has warmed up it starts first time.
Any ideas greatly appreciated
Old Oct 29, 2003 | 10:43 PM
Stu @ M Developments's Avatar
PassionFords Creator
Check the fuse to the heated seats.
Old Oct 29, 2003 | 10:45 PM
IANS2RST's Avatar
IANS2RST
already done that, fuse was missing when I got the car as was ke relay, replaced both of them and checked the feed to the fuel ecu.
Old Oct 30, 2003 | 03:30 AM
Ok.
Are you confident that all the rear plenum electrical plugs are in the right place?
This can cause it and very often does.
Old Oct 30, 2003 | 08:43 AM
IANS2RST's Avatar
IANS2RST
blue plug to cold start injector
brown plug to sensor below injector
black plug to aux air valve
yellow to sensor under inlet manifold
green plug for the knock sensor is not fitted due to someone fitting an early s2 manifold.
If this is correct then the plugs are fitted in the right order, knock sensor wouldn't make a difference would it?
When it starts it runs rough for a minute or so as though there is too much fuel.
Old Oct 30, 2003 | 02:01 PM
Check power to the black box is avaiable.
Old Oct 30, 2003 | 04:03 PM
IANS2RST's Avatar
IANS2RST
there is power at the box.
r u thinking its definately a problem on the fuelling side? cos the only thing that hasn't been changed is the fuel ecu itself which I was going to try at the weekend
Old Oct 30, 2003 | 04:15 PM
well.. it requires more fuel to run when cold. Its that simple really.
Other common option is coolant temperature sensor... Il BTTT a post on main forum if i can find it about this item mate
Old Oct 30, 2003 | 04:16 PM
IANS2RST's Avatar
IANS2RST
cheers
Old Oct 30, 2003 | 05:07 PM
No probs. Good luck.
Old Nov 1, 2003 | 12:49 PM
IANS2RST's Avatar
IANS2RST
still doing it, also pluged in another fuel ecu
Old Nov 4, 2003 | 01:44 PM
IANS2RST's Avatar
IANS2RST
now sorted
Old Nov 4, 2003 | 02:37 PM
Excellent news mate
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
