hi all new member
Old Jun 5, 2011 | 12:58 PM
jack2003's Avatar
jack2003
Default hi all new member
i just bought a st170 on a 53 plate 4dr hatch iv wanted one of these for an absolute age. and finnaly got over the insurance problem (insurane group 18) as i was using a 08 plate mondeo diesel for the past 2 years.
but am so disapointed the car is making a constant ticking noise.
ive been told it could be,
the inlet manifold flaps..
the shims..
the lifters..
so as i am wanting this car to work and doing it for the car as im never getting rid waiting over 6 years to buy one, so you can imagine my disapointment, i went and bought lifters shims and rocker gaskets and exhaust gaskets as well as head stretch bolts.
how do i change them. i used to be a saab tech (auto electrician) before going into engineering and i have desent machanical sense but can't find anywhere on how to do this job as there is no haynes book for it or anything online.
does anyone know of any how too's or pics of what to do, also ford said i dont need to drain the oil but do need to take it off the engine mount. that is exactly what they said.
thank you would not be enough but please does anyone have any idea as to do. thansk again all.
Old Jun 5, 2011 | 05:14 PM
ChrisH's Avatar
ChrisH
On an ST170 the shim is the follower unless someones done away with that like we did. So if the clearances are too big you need to buy a thicker follower.
Take the cam cover off, check the clearances using feeler gauges (To check a clearance make sure the lobe of the cam is pointing upwards on the clearance you're checking) Compare them with what they're supposed to be. If some of them are out, take the timing belt off and cams out, take the follower out using a magnet (a clean one) and measure it with a micrometer, record your result and then say the clearance is 0.15 and it's supposed to be 0.20 you take 0.05 off the follower size and you have got a rough size.
Old Jun 5, 2011 | 05:16 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
hi welcome mate, sorry i cant help with your problem but im sure someone will know
Old Jun 5, 2011 | 05:26 PM
jack2003's Avatar
jack2003
brilliant cheers chris.... just want it to be perfect am so disapointed but determined to correct it.
Old Jun 5, 2011 | 05:28 PM
ChrisH's Avatar
ChrisH
Not a problem at all mate. Keep everything clean and do one follower at a time otherwise it gets confusing. Also do be careful with cam timing and give it the two revolutions with a spanner on the crank pulley before cranking otherwise it may have another rattle!
Old Jun 5, 2011 | 05:32 PM
jack2003's Avatar
jack2003
cool i was ready to start ripping out the timing chain as it has never been changed.
had alook online everywhere for a workshop book but am sure its true as everyone has said there is no diffrence in the head or engine to a 2.0 zetec.. but is the head assembly the same?
cheers chris
Old Jun 5, 2011 | 05:40 PM
jack2003's Avatar
jack2003
chris
http://www.youtube.com/watch?v=RUw6_eO78OY&feature=related
this is the sound i have been told its injectors too, but again, are they the same assembly as the 2.0 zetec?
Old Jun 5, 2011 | 05:41 PM
jack2003's Avatar
jack2003
Old Jun 5, 2011 | 06:09 PM
ChrisH's Avatar
ChrisH
cheers chris
The head is different to a 2L Zetec, valves and ports are identical, first it has variable valve timing and the inlet cam is slightly different, the valve springs are different and 2.0L Zetecs have hydraulic lifters and ST170's are solid. It will bolt onto a Zetec block but you'd need to remove the variable valve timing etc but the ST170 head is better.
Old Jun 5, 2011 | 06:11 PM
ChrisH's Avatar
ChrisH
Can't really hear it in the video, needs some revs.
Old Jun 5, 2011 | 06:54 PM
jack2003's Avatar
jack2003
sounds like a astra diesel on first start and tick over tbh but sounds like lifters.. cheers again chris
Old Jun 5, 2011 | 07:01 PM
ChrisH's Avatar
ChrisH
Thats alright mate.
jack2003's Avatar
jack2003
chris sorry to be a pain, have you got any diagrams or any paperwork on the head workshop manual.
Old Jun 5, 2011 | 07:05 PM
ChrisH's Avatar
ChrisH
Can't say i have mate, sorry.
Old Jun 5, 2011 | 07:13 PM
jack2003's Avatar
jack2003
thats ok but thanks very much chris ill start stripping it and photograph everything.. cant go wrong then.
Old Jun 5, 2011 | 07:37 PM
ChrisH's Avatar
ChrisH
Thats the best way to do it!
