ECU Info- 2 Litre Blacktop
Old May 24, 2011 | 07:13 PM
prelude1980's Avatar
prelude1980
Default ECU Info- 2 Litre Blacktop
Does any one have access to the ROM stored on a standard ECU from a Car that ran a 2 litre Blacktop ZETEC either Mondeo or Focus.
I'm specifically interested in the spark table. I'm running megasquirt and hit a few problems so i want to compare to a standard table if anybody would be so kind
Thanks in advance
Old May 26, 2011 | 07:38 PM
Churtz's Avatar
Churtz
Hi
Are u running tps or map? And what issues have you found with the spark table?
I run ms1 v3 with a 2.0 blacktop supercharged engine.
Matt
Old May 26, 2011 | 07:41 PM
prelude1980
i'm running TPS, it's not so much problems just i want to try and check my timing map as i don't know if it's too much or too little to be honest
Old May 28, 2011 | 04:39 PM
Churtz's Avatar
Churtz
The best place I found for advise was on kitcar forums. They love ms and zetecs!! If u post a pic of ur ms spark table, I'll compare it to mine.
Matt
Old May 28, 2011 | 04:46 PM
prelude1980
Here's my spark table, i'll give the kit car forums ago too
Old May 29, 2011 | 09:00 AM
Churtz's Avatar
Churtz
That table shows that your running map..not tps?? Ur table is similar to mine, I start to advance timing to 18/19s at around 2k instead of 2.6k but definitely similar.
Matt
Old May 29, 2011 | 03:50 PM
prelude1980
Matt
Thanks Matt, It's definitely TPS, the column says CalcMap rather than just MAP as i'm running Alpha N
Old May 29, 2011 | 09:58 PM
Churtz's Avatar
Churtz
Ahhh that makes sense. I've just checked mine and it says the same.
Thinking back to previous mapping I've done, a company called DreamScience have the ability to read and edit ford ecus.
Matt
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
